1 - 5 of 5 Posts
I have a ST2 that was in a minor accident before I bought it. I replaced the headlights with cheapy eBay ones and getting the following DTC fault and message on the console that says "Headlamp Malfunction Service Required"
===HCM DTC B1D64:87-0B=== Code: B1D64 - Left Headlamp Swiveling Motor Additional Fault Symptom: - Missing Message Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Headlamp Control Module ===END HCM DTC B1D64:87-0B===
===HCM DTC B1D65:87-0B=== Code: B1D65 - Right Headlamp Swiveling Motor Additional Fault Symptom: - Missing Message Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Headlamp Control Module ===END HCM DTC B1D65:87-0B===
All the lights appear to be working fine so I'mt trying to figure out if this is like a fuse or electrical problem or the actual headlights.
Anyone know how to troubleshoot this? Maybe with a multimeter or something?
I'd happily get different headlamps to try fixing this is you guys think that will help.
Thanks.
If you bought non-adjustable headlights to replace the adjustable ones that have motor to do that the car may just be telling you it is not finding motors that should be there.........
Thanks. I wasn't aware the ST2 even came with HID adjustable lights but sounds like I may have bought the wrong ones. Are there any aftermarket ones that would work?
Otherwise I may try to code out HID via Forscan and revert back to Halogen. Would that work?
Fear the TurboSnail!
Yeah 15+ ST2, ST3 and RS have been he cornering lights where the lamp moves.
Sent from another garage.
1 - 5 of 5 Posts
