1 - 20 of 27 Posts
hi im new here I have a 2002 Focus SE, Atx with an SPI ive been doin a lot of reading on here but i cant find anything (using search of course) about if its possible to swap the spi cylinder head ot a Zetec one i was curious what the differences in the blocks are between the Zetec and Spi or if its just the heads that are different?? If someone could link me to the info id appreciate it cause I can get a Zetec head for about 80 bucks at local u pull
im curious too..i know alot of hondas you can swap heads and gain like 50hp
is the escort non spi the same? oh wait ..that would be going backwards in power right?
i have an old 94 escort 2.0 layin around would the head be the same?
Discussion Starter · #8 ·
NVRM i think i dont want to swap heads anymore i was on Wiki and was reading about the CVH engine class ......aka the SPI motor......for all of us SPI engine owners revel in the fact that u own a 4Cyl "HEMI"......CVH stands for Compound Valve angle Hemispherical combustion chamber. In 1987 ford added EFI and the Hemi head to the 1.9L Escort GT in 1997 they bored the 1.9L out to 2.0L..........o ya im just ganna chill with my 4cyl Hemi lol
2.0's did'nt come out untill 97.
It is possible to put a Zetec head on a CVH, but very impractical. You'd have to have many hour's in at a machine shop to get the water jacket, oil holes lined up right. Plus you'd have to some how replace the 2 valve piston with the Zetec's 4 vavle relief piston, and rig up the timing belt. Why not just save your self all that trouble and time and just swap the entire long block with a Zetec?
lol sorry i ment 1.9
and you would know this if anyone i think...will the zetec bolt up to my 5 speed and what all do i need..id like to build on in my basement and install it when its done
4cyl hemi? at 100hp?
Aurelius Pardus
WAT?[scratch]
yes jeff that's correct [giggle]
the IB5 won't fit the zetec and vice versa.... I believe the bell housings are different (is that what they're called? :B)
though if you have an automatic, they use the same tranny between the SPI and the Zetec, so that's why some may say that you can swap the transaxles between the two. just has to be automatic though.
as for the head, I'm pretty sure the 1.9 escort head works, since they look the same. at least that's what I've heard :B
Discussion Starter · #15 ·
ya but u gotta think hemi's wernt known for mad HP ratings they were known for crazy torque......and while i admit 125lb/ft aint that much think of it like this if this were a 5.7L V8 it would make over 300hp and 300lb/ft of torque which is IIRC about what the new Dodge Hemi's in the charger R/T 's make.......... with just a little massaging im sure i could get 150lb/ft of torque out of this motor which is what i want .............HP sells cars, Torque wins races.
EDIT: fyi the 5.7L Hemi in the Charger makes 340hp and 390lb/ft of torque, and the Charger weighs 4096lbs and im sure that is the dry weight.
Discussion Starter · #17 ·
I have a question about headers.... i know it doesnt have anything to do about the head swap, but im ganna hijack my own thread.....i have read some about using a zetec header on an spi motor.... i have also read that u need to mod the header to make the bolt holes line up and that that exhaust ports on the spi head are different than the ports on the zetec but that the header primary's are large enough that that isnt a problem...............so my question is this. Is is feasible to just cut the flange off of the zetec header an have a machine shop make a new flange altogether ??? or would that be really expensive??? i dont have any experiance with machine shops so i dont know what to expect on pricing????
No. The bellhousings are different.
1 - 20 of 27 Posts
