The 10.2 Pistons math was done with using the ZX3 HG if you go with the SVT you will lower the compression
I would do the math make sure the piston isnt in the hole to far CC the head add in the CC of the HG and make sure you have 10.2 then cut the head to get you to about 10.6 to 10.8
Just because you have 10.2 Compression pistons does not mean you will have 10.2 Compression if the piston is further in the hole than how the math was done you could have less than 10 compression
