1 - 16 of 16 Posts
So today I changed my pads out and pushed the car a bit. Came back home and saw a huge coolant puddle under the car. Popped the hood and saw coolant spraying from the bottom of the tank. Could it be a crack that opens up when pressurized? Engine was super hot. What should I do?
Sent from my SM-G950U using Tapatalk
Vive Les Revolucion!
Yeah, unfortunately, those plastic bottles are prone to thermal cracking...
Sent from my SM-G925W8 using Tapatalk
OR get the mishimoto version, which, yes its WAY more expensive, but is meyal so no more cracking or even odd coolant loss...
Yes as stated. Just replace. Tascaparts.com.
Should I get the system pressure tested and flushed? since this is the second time this happens in the span of one month. Think the coolant might have absorbed some moisture.
Gonna look it up. Hope it's not an arm and leg.
About twofiddy last time I looked... But comes in three colours, any of which will also dress up the engine bay... If thats your thing, that is...
Discussion Starter #8
Damn.... That's expensive. Just saw it on their website.
Told ya... But ANY of the OE tanks are gonna crack, depending on usage...
Discussion Starter #11
Update : Dealership changed the reservoir and the cap. Took 2 hours.
I’ve personally never had a problem with it other than the cap not wanting to come off. Strange.
Discussion Starter #15
Put 20psi to it and see how much the tank expands then you will see how cracks can form.
They did the pressure test and both the reservoir and cap failed. Guess my spirited driving fatigued the reservoir more than I thought it would. The Ford tech found stress cracks on the reservoir.
Torretto!
The mitsimoto is designed for st or rs... you can use it on NA but there is a tbing you have to do with one of the lines.. Mike from RDC can elaborate
1 - 16 of 16 Posts
