As the title states has anyone been able to pull apart the tail lights, like separate them? I am wanting to go gloss back around the chrome part and am trying not to use niteshade. Rather paint the housing.
Tail lights cant take much heat in the oven like headlights can. Also many tail lenses are ultrasonic welded to the housing so the oven won't undo the weld. Most people have to cut them open.
This is a common issue with the 08-11 taillights. It mostly is because the gasket where the bulb goes in goes bad. But as stated they cannot be heated nearly as much as headlights can. My chrome stock set actually warped from sitting on a shelf during the summer in my parents barn.
But I don't really want the dark chrome lights. I want the chrome to be gloss black, I might just get a set from the yard and experiment a little. Or just find dark chrome ones and call it done anyway.
HOLY COW this is so funny[ffrocks][headbang][hihi][hihi][hihi][hihi][hihi][rofl][rofl][rofl][rofl][rofl][rofl][rofl] everywhere you go on here everyone is fighting over something I would over look without even noticing
I made a video comparing $20 sway bar end links to ones that were less than $4.
I put the premium ones on my car first and they went to garbage within a year. I have had the cheap ones on there now for several months, and they've been better from day one. Just trying to help some people possibly...
Hi all, I have a 2008 Ford Focus SES that is having some problems starting. The vehicle started to intermittently struggle to start with the problem slowly worsening until the vehicle just will not start currently.
The best I can describe it is a stutter when starting that has slowly gotten...
Recently started noticing that 3rd gear grinds upshifting anywhere over 4500 rpm and the grind gets worse the higher up the rpms are. The car does not grind when downshifting into 3rd regardless of how aggressive of a downshift, just when upshifting. Car is a 2011 with 62k miles. I changed the...
I replaced my passenger side mount with an official Ford part about a year ago, and now it’s shaking again, but only when I have it in drive or reverse. The other two mounts are good. Has anyone seen the Ford mount fail this quickly?
Ok so recently I bought a 2010 SEL in Blue Flame Metallic. I knew I wanted a MK2 Focus for a while. I saw this one pop up for $2500 CAD ($1900 USD). I went to look at her and there was lots of cosmetic damage (scrapes, dents, etc.) it had a loose heat shield I’ve since repaired. There is rocker...
