Just installed that combo on an 04 svtf. Going to be racing it soon. I will update my thread as I put miles on it.
Worth it. I have a fidenza on my dd. pedal is just slightly firmer. Release so far is about 1-1 1/2 in from floor.
I used a Stage 3+ when I swapped to the 3L engine and then added the turbo to my Contour. After 7k miles the springs came out of the clutch hub and jammed up the pressure plate, it stopped releasing all the way.
Personally I would not use one.
I honestly do not know. I don't know how reliable they have been while used in the Focus. But on the Contour many have had all levels fail in some way.I am looking at the Stage 1 clutch kit, my cat has around 170-180hp so I am guess the clutch kit will do alright?
http://www.contour.org/ceg-vb/showthread.php?77218-Clutch-Failure-Links
Now with that said there are some that have a lot of miles on their Spec Clutches without issue. But they people purchased them before about 2004, iirc.
In my discussions with Spec they said it was because the MTX-75 doesn't use a pilot bearing is why I had issues. However, it used tapered roller bearings on the input shaft to do the same thing. Also my MTX-75 was rebuilt and only had 14k miles on it at the time, 7k miles I put on it. I also made sure I broke the clutch in the best I could, for 1k miles. The boost was added later.
So its up to you to do some research and made the best informed choice you can.
I wish you luck then. I can see them as salesmen saying that past issues have been corrected to make a sale.Thanks for your advice, I have just talked to the people in SPEC, they said the previous durability issue have been solved and the newer products on 2012+ focus will do just fine. I actually bought a set of stage 1 clutch kit with a lightweight flywheel, will post some pictures while installing.
Neo
Well, I installed the SPEC billet flywheel and stage 1 clutch about 4 months ago. After 5k miles, I love it. Took about 1200 miles to break it in since I didn't drive 450 in the city.
