1 - 1 of 1 Posts
Vendor
The suspension is one of the most important factors in determining your Ford's day-to-day drivability. Upgrading your stock springs is the first step in suspension tuning and H&R is one of the industry-leaders in this area. Their lowering coilover kit is an excellent suspension upgrade that gives your Ford Focus ST/RS an awesome look along with a huge improvement in handling performance.
With H&R kit on you'll get a slightly more aggressive stance than your stock suspension offers while still maintaining a comfortable ride. Each H&R coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system. You would be able to adjust the height of your Focus with the fully threaded shock body, which helps balance vehicle weight, resulting in a lower center of gravity and improved control. Also, H&R fine-tune each coil-over shock with a progressive rate spring to ensure better handling and premium ride comfort.
H&R® -1 - 1"-1.75" x 1.2"-2.2" Street Performance Front and Rear Lowering Coilover Kit for Ford Focus RS
H&R® - 1.2"-2.5" x 1"-2.3" Street Performance Front and Rear Lowering Coilover Kit for Ford Focus ST
*Pictures courtesy of IG @hrspringslp
H&R™ | Springs, Coilovers & Suspension Parts — CARiD.com
Enhance the look of your Ford Focus ST/RS with a reduced fender well gap - choose H&R Lowering Kits at CARiD!​
1 - 1 of 1 Posts
