1 - 4 of 4 Posts
okay, so i need to buy some leds for replacing the map light bulbs... i took apart the dash to see if i could replace the lights with different color leds to make it a different color...
my questions are... is that possible, or is there a film that changes the color... and 2.... if it is possible what size do i need? T1-1/2(#73/74)?
If it's just the stock gauges then you can take the gauge face off and sand teh green film down and then replace the bulbs for blue LED type ones. You should not need to solder any leds as they just swap in if you get the correct bulb type.
EDIT: Here's a guide for doing LED stuff including the gauges I found over on the UK focus site. LINK
1 - 4 of 4 Posts
