1 - 8 of 8 Posts
· Registered
Howdy all. Didn't see an 'introductions' forum or a reqiurement for a 'hello' post before jumping in with technical questions, so here goes both at the same time.
Not certain there is a good way to make this long story short, so I'm just going to string it all together.
I'm trying to help someone keep a 2004 focus ZX4 running as long as possible. Several sets of wheel bearings, exhaust repairs,, suspension repairs after bashing curbs, etc.
But now, there's a running problem that is kicking my ass. This car will be driving along just fine and then all of a sudden the power output of the engine drops to effectively nil. It doesn't die (sometimes it dies, but not always). It doesn't run rough or drop cylinders (although sometimes it kind of 'chugs' as though the condition is coming and going very rapidly. But the main symptom is hp output disappears. Typically a restart is required and then everything is fine again, until it happens again.
As stated in the title, it's not setting any codes or giving a check engine light, even as the problem is occurring. Which I find strange.
The fuel pump was noisy. It has been replaced this week along with the fuel filter.
The MAP sensor has been replaced, the throttle plate has been cleaned, and (thanks to old brittle plastic and rubber in very cold temperatures) the fuel rail pressure sensor has been replaced, too.
I've found one fellow who referenced a vehicle speed sensor issue that apparently can do something like this, but I don't recall the speedometer dropping out when it acts up. Another thread mentions a harmonic balancer that was the root of the problem.
Does anyone have any insight for a focus that just forgets how to make HP until a restart?
· Registered
2004 ZX3 SVT EE 181k miles. 2004 ZX3 SVT 199k miles
Check for damaged wiring to the front oxygen sensor and the crankshaft position sensor. The wiring is supposed to have a plastic cover but they have long since disintegrated and the wiring can wear through where it runs over the transmission.
· Registered
Discussion Starter · #5 ·
O2 sensor bank 1 sesnsor 3 runs the fuel trim at 99.2+ at all times
Car begins to exhibit the stalling/chugging/dying symptoms on long deceleration
One time it did it's 'chugging' at idle in gear after a stop and I was able to observe on the scanner the computer bouncing the timing back and forth from -14 to +3/4/5 degrees, with the engine speed corresponding to the various timing settings (slow when -14, speed up when 5+)
Sitting at idle you can watch the B1 S1 o2 voltage drop to all zeros, computer appears to be removing fuel in response to those lgigantic fuel trim numbers
· Registered
O2 sensor bank 1 sesnsor 3 runs the fuel trim at 99.2 at all times
One time it did it's 'chugging' at idle in gear after a stop and I was able to observe on the scanner the computer bouncing the timing back and forth from -14 to 3/4/5 degrees, with the engine speed corresponding to the various timing settings (slow when -14, speed up when 5 )
check tps,, could be done
· Registered
1 - 8 of 8 Posts
