1 - 8 of 8 Posts
· WhiteSTguy
Well the post lady just dropped off my new clutch today but I have one question. This is the newer bigger clutch. Is there a way I can check before I tear my car apart if I have the newer TSB clutch already in my car? I probably should have done this before buying the clutch. I also have an 04 so I should be fine right? I heard somewhere that they changed them in the middle of the 04 year production or was that in 03? I'm hoping this will be a direct replacement.
· Registered
As was posted a while back, there were no SVTF's that came from the factory with the TSB clutch. ford only replaced the one's that failed with the newer clutch.[ffrocks]
· WhiteSTguy
Discussion Starter · #4 ·
So I guess that means that I need to buy a newer updated flywheel? Or can I use my existing one?
· Registered
the SVTF flywheel is a throw-away, It can't be resurfaced. unfortunetly when our clutches go you have to replace everything. One can be hopeful and not have it blow apart and take the trans with it.
· WhiteSTguy
Discussion Starter · #7 ·
Thanks for the reply! I contacted a guy selling a Findanza FW on this site and I'm just waiting for confirmation if it's compatible with the LuK clutch kit I just bought. If so it's all mine [:D]
1 - 8 of 8 Posts
