1 - 20 of 31 Posts
Long time lurker, first actual post. I've had my 07 ST for about 4 years now. It's done me well but a few of the common issues with the 2.3 are piling up and instead of fixing it I will be upgrading to the 2.5. My intake sounds like worn out sewing machine and the thermostat keeps throwing the I'm too cold code. Not to mention at 130k on original clutch is starting to get weak and the flywheel shudders bad when cold.
Here's the plan.... 2.5 out a 2010 fusion with vct del/bsd along with the Mazda 3 dual runner intake. Doing the massive oil pan insert after the bsd. I will also be using the exedy stage 1 clutch with lightened flywheel. Going to use stock 2.3 cams as well as the exhaust gear on the intake cam to bypass the vct.
I'm not looking for full on race build, just a couple extra ponies and refresh a few things along the way. I've got an extra transmission with the 3.86 ratio and an extra 2.3 to steal all the parts off of while I still drive my car and build the 2.5. I have 3 other vehicles which include a 7.3 diesel F250, V8 swapped Ranger and a supercharged Mustang but like to bebop in the focus the best.
I'll start posting pictures shortly.
FF Affiliate
If you add the STG3 Crower cams now and adj cam gears why you have the timing cover off you will be WAY ahead and the gains will be noticeable and well worth the money , I think the Fusion intake does just as well
I'm more or less looking for a stock plug in swap now. This is my car I like to jump in and go 500 or 1000 miles without a concern. I've been able to hold out with just a cold air intake as far as motor mods for the last 70k miles I've had it. Its lowered on ford racing stuff, sway bars and svt brakes front and rear so that's all covered.
I've got a stage 1 non intercooled 8psi kit sitting on my shelf. Bought it used 2 years ago and haven't put it on because once you "mess" with it you open up the possibility for issues. If I decide to do up a motor with cams and what not I'm going to do the bottom too.
My cable throttle body solution on the intake will be a 65mm Explorer 5.0 throttle body. I'll make an adapter to mate the two. That way I can still keep the iac on the tb. I'll probably get an sct to mess with the idle. Probably need to get with you on that as my pcm strategy is not supported with the sct preloaded tuners.
FF Affiliate
The preloaded Tune wouldnt work anyway , let me know if I can help , Focus Salvage and massive has adapters for the Focus to Fusion intake
I want to take advantage of the large 2.5 intake ports which is the reason I want to use the explorer TB /mazda intake. The inlet on the Mazda 2.5 intake is 63mm. I'll keep the fusion intake incase I do decide to do the turbo, won't need the intake to give me the low end torque anymore. The focus cable tb has that weird inlet for the iac and is pretty small. As a last resort I can modify my tb adapter to also accept the focus tb and remote mount my iac.
I have an SF3 tuner on my 01 ranger (running 97 explorer 5.0 pcm) and on the canned tune I was able to adjust idle speed. I've got a livewire on my 7.3 but never messed with anything other than my tow tune. My diablosport on my mustang allows me to adjust idle speed on the custom tune, something I don't think I can do with the sct. Good to know there's active tuning knowledge on here, it's the main thing I'm noob on with the focus.
w/ my magic bag
btw, cams do make a big difference & since your there why not? You don't need to do anything to the bottom end as you would w/ a turbo upgrade....
Discussion Starter #8
So the main reason I'm trying to keep it stock for now as I have a 1000mi trip I plan on taking it on come April. I don't have enough confidence in the clutch making it daily driving it until then and doing the swap only makes sense since I have 90% of it. I don't know if I'll have enough time to get it all dialed in by then if I throw cams into the mix too. I was going to try to avoid tuning and tweaking until after the trip. Then again Tom probably has a tune for every setup I could come up with he's previously done.
I own my own small repair shop so I'm fully equipped to get it done, just got to find the time. I'll get some pics of everything I'm working with in the following days.
w/ my magic bag
You can buy my moddit foci & drive it anywhere, deadnuts reliable.....
Discussion Starter #10
I'm good, I already have about 10 extra vehicles parked around the shop in various states of repair including an 02 svt focus I could move on to. Plus I really like my ST.
I'd just throw the clutch in it an roll on if I had doubts I could get it ready in time. But with multiple lifts and tools I have no excuse to not finish a motor/trans swap in 2 days.
w/ my magic bag
Guess you don't know my foci......Yea 10 xtra vehicles is a little much....My car is ready to roll & needs no upgrades.......
Discussion Starter #14 (Edited)
Tapped the oil hole to 10x1.5 (same as other mount holes). Then cut a bolt in a way it would clear the 2.3 timing cover and used high temp thread seal. If you do it this way make sure thread length is cut to no longer than 5/16". If I had more time I'd of used a plug instead of a bolt.
305182
305183
Discussion Starter #15
2.3 factory cams installed with exhaust gears from 2.5. Used Ford bolt instead of one included in massive kit. I like the shiny of the massive washer but I have more faith in the factory bolt.
Oil pan baffle and balance shaft delete done.
305187
305188
305189
Discussion Starter #20
Dipstick mounting point glued on with industrial 2 part super glue. Cut an ear off a thermostat housing and ground it to fit the contour of the intake. Had to clearance some if the webbing to get the dipstick to mount nice and tight.
305211
305212
305213
305214
1 - 20 of 31 Posts
