21 - 25 of 25 Posts
Did the dealership repair your Purge valve issue under warranty?
Are you referring to the current recall (07/19) where they check for gas tank deformation, PCV valve related codes and perform a computer update? Yes this is covered under the recall for free. If needed they will replace your gas tank and/or PCV Valve. In my case the tank was good, they replaced the PCV valve and reprogrammed. It took about 40 minutes.
how do you know if it has the dps6 ? we had our 2012 since 2013 and not had one trans problem yet and its 105000 miles.
If it has the automatic transmission, then it has it. My 2013 has it also. Since the collision I was in and since the tcm was fixed, knock wood, it's been pretty good. I mostly put highway miles on it. So at least that is probably easier on it.
21 - 25 of 25 Posts
