2006 Focus 2.0 TDCi. On Friday the car wouldn't start found air in fuel line, bled and started fine. took a drive on the main road to give it a quick run and the safe mode set in. got back home and switched off and all was fine for the weekend, no hassles.
today Tuesday on the way home from work I switched off and removed the key only to find that the engine was still running. I then used the key to switch on and off a few times before it died.
I then removed to battery for about a minute or so and then it was fine. about 30 min later the alarm lights were flashing so I disarmed it and started the engine and when I switched off it continued to run (keyless)
what to do?[screwy][screwy]
