1 - 10 of 10 Posts
TDCi2.0 2006. when I switch off key and remove it the engine keeps running. the radio goes off but the other normal ign lights remain on eg oil, park brake, and battery lights. I stalled it to stop the engine but the ign was still on. when I get it started it runs fine without any problems. but when I want to stop the engine I found that after switching off the key, when I depress the brake peddle the engine dies and after releasing the brake peddle the ign lights come on again.
I have disconnected the battery for 2 hours+ and when connecting it again the wipers move, the dash lights all glow some flash
it is with a ford electrician as I type (he's scratching the head too)
But when it runs, it runs well!!!
any advice would help.[bigcry]
Discussion Starter · #4 ·
ok, so here's the latest. if I remove the power steering fuse then the car "behaves" but the steering plays up when driving. if I replace the fuse when engine runs all goes well.
the cigar lighter has permanent power, is that correct???[scratch]
Yes, cig lighter always has power.
Your other car problems are strange. The ign switch is more than a switch, it is a set of 4 independent switches; and each one does more than just on -or- off.
You may have one or several electrical problems, but if I were you, I would replace (or test the hell out of) the ignition switch. Also, consider testing the wiring (I/O signals) of the Power Hold Relay.
Discussion Starter · #6 ·
update! after cleaning earth points the car behaved .......... until now. i fitted a toggle switch to the fuse to be able get around.
i have a new issue with the ESP and ABS. i suspect the speed sensor to be dirty/faulty. the diode of previous chats is nowhere to be found. i have even asked local mechanics and electricians but all had the same excuses....... ummm aaaahh dunno.
will update soon .... of to the garage
This is more out of curiosity. How old was the battery and did you have the alternator checked? I had a Chevy Chevette that had a ground wire to the alternator rub through going under the air cleaner. I didn't want to just start yanking on wires so it took a while to find it. By the time I did it had ruined the battery and the alternator. I know they are vastly different cars but I thought I'd mention it. If the bad battery played havoc with the electrical system it could have put a higher than normal load on the alternator too and you could have it die on you.
1 - 10 of 10 Posts
