1 - 13 of 13 Posts
Getting the Alt out is a bad fuc%$$#ing Joke that ford played on me,,,
wow only took me 2 1/2 hours to het my alt out,, i had to take the motor mount off, pull engine forward and drop out the bottom between rack and exhaust,,
im 46 and i have never been so fuc*(&^%^ed around by a car on a simple job
2003 focus zx3
jesus...even with taking my whole supercharger off, it took me and my friend about 45 min to remove and replace mine.
We just had our alternator replaced. What Sears told us was a 1.5-2 hour job...turned out to be 4 hours.
Our car is a 2003 ZTS
OMGVTAK!
I'm dreading the day mine has to be replaced. Everytime I open the hood and look at it I say 'Holy s$#@ that's gonna be fun'[:(]
Discussion Starter · #6 ·
really...... did you take it out through the top ,,, ou out the bottom...???
I"ll be out of town that weekend ^^^^[:D]
They come out the top, no sweat, just move the purge solenoid and the PS tank. I think I moved the bracket out of the way, too. I've done a few of them and they look 10 times harder than they are.
yeah i moved mine out of the way when i installed the 2000 IM, I think the whole install took that amount of time, the alt was nothing really....
Discussion Starter · #10 ·
I moved the PS tank,,, But
sorry for the novice question,, but im putting the new one in tonight... what is the "purge solenoid,, is it that silver diaphram looking thingabout 1 inch in diamater with a vac hose to it mounted to the engine hook on bracket...??
What bump stop?
the evap purge canister. It a black cylinder looking thing on the firewall, has a vac. line going to the intake mani and 2 hard lines connecting to it.
I've had to replace a "few"[:D] in my time on the foci and it's really not that hard. I've never had to pull the mount either, though one time I was thinking about it just to make it easier.
As long as you remove everything in the pass. side corner, evap purge, ps res, coolant overflow, disconnect the engine ground and harness, it wil come right out.
Also a tip for anyone that hasn't done it yet, when wiggling the alt out of the hole you just made, make sure the pully is facing up, it come out the easiest that way. Same for putting it back in, pully up and gravity pretty much takes over[thumb]
Discussion Starter · #12 ·
thanks much,,
Ill use your method tonight,,,,,!!!
Anything but getting under the car and passing it up [ to no one ] as im doing the job alone,,,,,
Thanks
1 - 13 of 13 Posts
