21 - 22 of 22 Posts
Jerry, does the late cooper S G285 have a taller or shorter final drive than the SVT? I’d be interested in getting tighter gearing for around town if I can just go pull a few gears out of a trashed mini.
Here are the different ratios. For your purpose, look at the "early" Mini gears, the switch came in July of 2004. The SVT should have the early (slightly taller) gearing. I started with the later ratios, which are a little stiffer:
|Mini Cooper S ratios |**** |
| 1 |** 11.425* |** 12.789* |
| 2 |*** 7.181* |*** 7.793* |
| 3 |*** 5.397* |*** 5.651* |
| 4 |*** 4.407* |*** 4.615* |
| 5 |*** 3.656* |*** 3.828* |
| 6 |*** 2.986* |*** 3.126* |
| R |** 11.130* |** 11.944* |
*** | > 06/2004 | 07/2004 > |
MINI Diesel:
| G |********** |
| e |* Overall* |
| a |** Ratio** |
| r |********** |
| 1 |** 12.570* |
| 2 |*** 6.990* |
| 3 |*** 4.510* |
| 4 |*** 3.550* |
| 5 |*** 3.050* |
| 6 |*** 2.410* |
| R |** 11.130* |
I don't know what the individual gears and rear ends are. As you know 3rd and 5th are the same gear as is 4th and 6th. I can list speed in gears for both, but I don't have a chart, so it would be a little tough to show.
Just getting acclimated, but the ratios are working exactly as I thought. 1st is almost the same, but by the time I hit 3rd it is the same as old 4th. 4th is about the same as old 5th and new 5th is a little taller than old 6th. I go from about 23 mph/1000 rpm to 30 mph per 1000 rpm in 6th. The drop on the highway (where is matters, driving in town is just in 1 gear lower) is about 500 rpm. I will get a better feel as I put some miles on it.
Am I happy? Actually, yes. I know I was giving up torque multiplication, so when I have done this on other cars (just swap the diff and reprogram computer), I always added some mechanical power to offset the loss.
I think the engine will be more relaxed on the highway, improve mpg as a side benefit and adding back power to the motor will negate the taller gears. For the Mini, the 6 speed automatic has virtually the same top gear ratio as my new setup, so I know the motor can pull the gear, even stock. Only difference (with new cam setup) is the power has moved up the power band, so if I want to hustle, I need to spin about 3500, where she really pulls hard. 6th gear will be primarily highway, above 60 or 65 mph.
Regards,
Jerry
Hey Jerry,
I hope all is well and you are continuing to enjoy your new transmission setup. Could you report on if you have noticed any difference in MPG post swap?
Thanks!
21 - 22 of 22 Posts
