421 - 438 of 438 Posts
Has there been a general consensus with the 63mm throttle body then that it’s A) Safe & B) worth while with proven gains? I’ve been mia for a while.
I’ll be throwing a new set of plugs in at 75k miles and might consider doing this while I’m at it.
Dyno with 2.0 NA, 3" Thermal R & D catback, Drop-in filter and stock airbox, 63mm TB and Devil Tuned
Sent from my SM-G935V using Tapatalk
It's safe, no gains but my throttle response has improved alot. Other members can also vouch for the increased throttle response :)
Sent from my 2PS64 using Tapatalk
#dailydriven
Discussion Starter #424
I doubt you'll see any gains in WHP but it seems to help with throttle response. It's cheap and easy to install.
I dunno, once tuned for the TB gains changed, so maybe a slight gain
#dailydriven
Discussion Starter #426
Sent from my SM-G935V using FF Mobile
I noticed your dyno number were pretty much the same as when you put it on the dyno with the 2.5in exhaust you used to have. Do you think the 3in exhaust made any difference then? the tq numbers look similar too.
Last time was true CAI also.. so doubt exhaust size made much difference. Gains are avg for the Devil Tuned NAs, cams coming soon
#dailydriven
Discussion Starter #428
are the cams the reason you guys decided to go 3in with the exhaust then? or the future header?
The 2.5" magnaflow i was using droned at higher rpm, and the Thermal system doesnt. And we were wanting to become a thermal dealer
Got the throttle body ordered with gasket and bolts from white lake ford. $71 shipped can’t complain. Thank you Fabio for the part #’s
Torretto!
Without a 3" collector on the header, a 3" wont make a big difference, flow is only as good as biggest bottleneck.
Torretto!
Sent from my 2PS64 using FF Mobile
Mike, what can you adjust in the tune to make the Tb work better? I've noticed 75% to wot car pulls harder, more touchy throttle...worthwhile mods for the price
FF Affiliate
I cant speak for mike but I make 9 change for the TB change , biggest to WOT/WOP and the Effective Throttle area are the 2 biggest , to me just makes it crisper and more responsive altho its slight
True, but coming header will be 3"
Does the focus need tune after installing the Eco mustang TB ?
Tune definitely helps
Foci-philes:
Finally got around to installing the new throttlebody today and what a very pleasant surprise: it is truly a plug-and-play mod and it crisps up the throttle response very nicely. If you're on the fence, hop off and do this mod. It is inexpensive and the throttle response is noticeable even without a tune. (I do have Tom's basic tune but I need to datalog and have him work his magic.)
Nice mod!
Chris
