1 - 12 of 12 Posts
Got GAZ rear shocks from BAT Performance. They are REALLY nice. Anyway, have any of you guys run GAZ shocks? I was going to run these with the FRPP springs and FRPP dampers up front. These are adjustable and can be used with lowering springs. My rear is a little loose in the twisties and I'm thinking dialing these in will help it out. I'm thinking I may need to wait to install them until I get the matching fronts. Have any of you guys ever run mismatched dampers? Plus, I'm not sure if the fronts are compatible with the 08+. I think I'm going to give BAT a call tomorrow.
w/ my magic bag
^^ Your there, I'd do the front's too!
Shiny Metal Titanium
Isn't that what the Omni kit is for? To fit the older struts in the new cars?
^yeah, I'm just trying to figure out if I need it or not.
OK I talked to BAT. The GAZ shocks are good up to the 05. So I'll need the Omni kit.
Got my GAZ adjustable shocks and Focus RS springs installed today. Props to my boy JGrove for the help!
Discussion Starter #8
^awesome, they handle better than the FRPP dampers.
Discussion Starter #10
I'm not sure on the specs, but they feel stiffer than the FRPPs. The car sits a little lower than the FRPP kit.
w/ my magic bag
Look's great, Like to see a pix from a little lower thou. & the spring's will settle to you know. RS spring's huh, where you get thou= Bat? How do you like thou strut's/shock's compared to the Koni's?
Discussion Starter #12
I got the RS springs from a guy over on FJ. Somehow he got them from Ford of Europe. I wasn't running Koni's before, I had the FRPP kit. I have no complaints on the FRPP kit, but this set up is DEFINITELY an improvement.
1 - 12 of 12 Posts
