Interesting bit below. Its not just a standard motor that retards timinig to "slum" it on regular..its a different beast. Do you honestly think that if Ford could squeeze better performance/economy out it by using premium they wouldn't recommend it? (Maybe I should have said "Do you think Ford would purposely design a motor that runs inefficiently on regular and then recommend that as the fuel type?")
"A couple of key technologies allow us to do that, and one is direct injection," said GM's Davis. "One of its big benefits is it provides a cooling of the of the intake charge in the engine. That cooling suppresses the autoignition reactions that lead to knock. In a sense, by adding direct injection you can lower the octane requirement of the engine. The other contributor to knock is the combustion process itself. By a careful design of the combustion system geometry, the shape of the combustion chamber, as well as the airflow characteristics and the flame propagation, you can actually make the combustion system more tolerant of the lower octane fuels."
At the end of the day, I don't care what fuel folks run, but I think the premium bit is a bit placebo..but maybe I am wrong. I have tried it multiple times and not noticed any real difference whether on the highway or around town (performance or mpg). Dyno results would be interesting and may tell a different story. Yes..I realize the 2012 manual says that you can get increased performance running premium but its not in there now and I think this is b/c it was a mistake/carry-over from the ST manual. Again, just my opinion.
