1 - 10 of 10 Posts
hey i just put in some of those fancy headlights with the halos in them. Alright i tapped into the the front break light. Worked fine for a while then poof the passenger halo and runnng ligt donot work, not on the side or the rear. yet the turn signals and break lights work. I did not properly ground the wire on that side and methinks i blew a fuse. Do you think so?[?|]
If you didnt use a resistor on the halos you probably blew the LED for the halo.
Well, first of all, if you didn't ground it right, it wouldn't work at all.
Second, there is no "front break light", I have no idea what that is.
There was someone on here who installed neons and did the exact same thing, on one side the parking lights/running lights wouldn't work. However, now that I think about it, I can't for the life of me remember what the problem was.
All I can say is recheck all of your wiring, and check your fuses. Let us know what you find.
Discussion Starter · #4 ·
funny thing is that it worked for a little then the damn parking lights went out. if it is a fuse or relay do you know which one it would be
Your owners manual will tell you which fuse is for the parking lights. Sorry, I would consult my Focus owner's manual, but it was in my glove box when I traded my Focus in.
*edit* Yes, I think he ended up fixing it, come to think of it, I believe it was a direct short to ground and it blew a fuse. Like I said, recheck your wiring to make sure nothing has shorted out (like bare wire against metal) and then check your fuses.
As you are describing it, no. The whole purpose of a GROUND wire IS to contact metal, otherwise it wouldn't be "grounded".
mine are hooked up without the resister because the resistor made them very dim, mine still work fine
Discussion Starter · #10 ·
okay for the final time. The ground was not secured very well. Thus it would on occasion, cause the halos to go out. Now the ground is more secure. Now i was wondering if the losse ground would cause a short. There it is
1 - 10 of 10 Posts
