1 - 5 of 5 Posts
Hi everyone! I was wondering if anyone has the full TSB text for TSB 19026, nhtsa 10019081. I am getting the p0316/p0303 misfire in cylinder 3 code, and just pulling the plug everything looks fine. The TSB is about this code so it might have some helpful info. Thank you so much!
Stupid TSBs, why aren't they online? [screwy]
This is all I ever find:
DTC P0316, P0300, P0301, P0302, P0303 and/or P0304 - service tip.
C2H5OH
Just a quick Google of that # and I get results for '04 and newer, duratec I assume and something relating to the COP ignition system (red dust ?).
And TSB's are generally meant for the dealers, sort of a database for common problems/fixes that are non-safety concerns; not so much as public info.
Any way, try swapping the coil and see if the misfire follows. If it does I''d say the coil is bad.
I tried searching your TSB number on our in-house service info (I work for Ford) and that number is invalid.
I have pinpoint tests but there's about 40 pages worth of them.
Start by making sure you have a good clean spar, then move on to check your injectors, then your cylinder.
Easy way to check the injector is to swap it with one of the other ones and see if the code changes.
Found it, Here you go.
FORD: 1997-2002 ESCORT
2000-2002 FOCUS
MERCURY: 1997-1999 TRACER
This article supersedes TSB 02-09-01 to update the service and part information.
ISSUE:
Some vehicles equipped with the 2.0L SPI engine may exhibit a malfunction indicator lamp (MIL) illuminated and diagnostic trouble codes (DTCs) P0300 through P0304 stored in memory. The vehicle may also have a rough idle or reduced power condition, and/or may stall at an idle. This may be caused by sticking exhaust valves due to excessive carbon build-up.
ACTION:
Check for faulty fuel injectors and ignition wires. One or more exhaust valves may be temporarily sticking due to carbon build-up between the valve stem and guide. If the diagnostic checks point to a sticking exhaust valve, the cylinder head assembly may need to be replaced with a new level cylinder head assembly with revised valve guides, revised exhaust valves will also need to be installed to help prevent carbon build-up. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
NOTE: THIS PROCEDURE APPLIES ONLY TO THE 2.0L SPI ENGINE.
This condition usually results in misfire when the engine returns to idle after running approximately 2000 RPM or higher.
Use the worldwide diagnostic system (WDS) to test for Power Balance with the engine at idle. Check for cylinder misfire. If misfire is occurring constantly, go to Step 3. If misfire is not occurring, attempt to induce misfire by performing the following step:
Apply the parking brake and keep the transmission in Park or Neutral. Bring the engine to approximately 2800 RPM and hold for one (1) minute. Check the WDS Power Balance display while holding engine speed constant. Allow the engine to return to idle and watch the WDS Power Balance display for a misfiring cylinder.
If WDS Power Balance indicates a misfiring cylinder with the previous test, one or more exhaust valves may be intermittently sticking due to carbon build-up between the valve stem and guide. Replace the cylinder head with the new level cylinder head with revised valve guides. Once stock is exhausted of the loaded cylinder heads, the cylinder head will come bare so revised exhaust valves will need to be installed in place of the original valves. The revised valve guides and exhaust valves help prevent carbon build-up. Consult the appropriate model year Workshop Manual for removal and installation procedures for the Cylinder Head Assembly.
If WDS Power Balance did not indicate a misfiring cylinder with the previous test or a misfire is occurring constantly, the misfire may not be due to a sticking exhaust valve. Refer to the appropriate model year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual for further diagnosis. Other possible causes may be, worn or arcing ignition wires, base engine compression, fuel injectors, fuel injector harness resistance or PCM injector driver signal. Perform diagnosis and repair as necessary.
After completing either Step 2 or Step 3, replace the PCV Valve (YS4Z-6A666-AC) (Motorcraft EV-244) on model year 2000-2002 Focus or 2000-2002 Escort. Vacuum fluctuations from engine misfire may prematurely wear the PCV valve on those applications.
NOTE: THE CYLINDER HEAD ASSEMBLIES LISTED BELOW WILL BE BARE CASTINGS ONCE SUPPLY OF LOADED HEADS IS EXHAUSTED, IN MOST CASES IT WILL BE NECESSARY TO REPLACE ONLY THE PARTS LISTED BELOW, ALL OTHER PARTS CAN BE REUSED.
2000-2002 Focus
Part Description Part Number Qty
Cylinder Head YS4Z-6049-GA 1
Intake Valve F7CZ-6507-CB 4
Exhaust Valve 2M5Z-6505-AB 4
Valve Stem Seal 1S4Z-6571-AA 8
Front Cam Seal E7FZ-6K292-A 1
Rear Cam Plug FOCZ-6266-A 1
Cylinder Head to Block Gasket YS4Z-6051-BA 1
Cylinder Head Bolts (pkg of 10) E4FZ-6065-A 1
Cylinder Head to IMRC Gasket YS4Z-9439-AA 1
IMRC to Intake Manifold Gasket YS4Z-9H486-CA 1
Intake Manifold Stud W706759-S309 2
Exhaust Manifold To Head - Gasket F6CZ-9448-AC 1
Exhaust Manifold Stud F7CZ-9454-AA 8
Exhaust Manifold Nut W701706-S2 8
Spark Plug AGSF34F-MF6 4
Exh. Manifold Collector Gasket F7CZ-9450-FA 1
Catalyst Nut W703933-S403 4
EGR Tube Gasket F6CZ-9C435-AA 1
EGR Tube & Exh. Manifold Shield Nut W520101-S309 7
PCV Valve YS4Z-6A666-AC 1
2000-2002 Escort
Cylinder Head F7CZ-6049-CAA 1
Cylinder Head to IMRC Gasket XS4Z-9439-CA 1
IMRC to Intake Manifold Gasket XS4Z-9H486-CA 1
Intake Manifold Stud N808685-S309 2
Water Outlet Gasket F6CZ-8255-AA 1
Exhaust Manifold To Catalyst Gasket F7CZ-9450-FA 1
Catalyst Nut N811499-S101 4
1997-1999 Escort/Tracer
Cylinder Head to Block Gasket F7CZ-6051-BB 1
OTHER APPLICABLE ARTICLES:
NONE
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
Discussion Starter · #5 ·
Thank you! Yikes, I hope it is not an injector or cylinder head. I'll look for spark then try swapping injectors like you suggest, I think I will also ohm the coil. I'll let you know!
1 - 5 of 5 Posts
