1 - 5 of 5 Posts
i have an 03 focus.a month after i got the car,everytime i would fill it up it would go to E and wouldnt go back up untill 20-40 miles later.......now when i fill up the neddle will go to E and the after i drive 10 miles it will change randomly every time i shut the car off and than back on......
If its random, it could be a loose connector on the top of the tank, its a bear to get to , though.
I'd also checked the fuel level sensor. It's basically a float attached to a potentiometer. When the fuel tank is full and the float is as high as it can be, there's a certain voltage. When the level drops, the voltage changes. The gas gauge is basically a voltmeter if you think about it that way.
Once you get to the top of the tank, remove this sensor and attach a voltmeter. As you move the float up and down, you should see a consistent voltage change. It's not uncommon for these to fail after a while. When they get rusty and corroded, you'll experience symptoms like you're having.
The Librarian
Quit topping up the tank so much...
You topped it up too much when you filled the tank.
I had that exact same problem, and once I stopped topping it up several times when filling, the problem stopped.
Lemme find one of the threads...
Here's one:
http://www.focusfanatics.com/forum/showthread.php?p=2102710#post2102710
Another one:
http://www.focusfanatics.com/forum/showthread.php?p=779960&#post779960
And, here's my thread when I first had the problem.
http://www.focusfanatics.com/forum/showthread.php?s=&threadid=48458
1 - 5 of 5 Posts
