1 - 1 of 1 Posts
I have to install a fuel return barb fitting on the end of a 2000 Ford Escort 2 liter Zetec fuel rail. The rail appears to be made of chrome plated steel tubing with the end caps and bungs soldered or welded on. I guess I will have to build up the end cap, sweat solder or tig a plate or bung on, so I can drill and tap for a ¼” pipe threaded barb fitting.
Has anyone worked with this fuel rail and done this job? How are the caps attached? Soldered or welded with what filler?
Thank you for any help or ideas on how to do this.
1 - 1 of 1 Posts
