Fuel pump location for access door.
2476 9
I have an '06 ZX5 and want to replace the fuel pump without dropping the tank. Every place I have seen info about the location to cut the access door does not seem to be where I need it. What I have seen shows the hole being cut in the front passenger side above the tank. I have not been able to see anything but tank in this location. Were there other tanks used that would have had a different location? I have drilled several holes so as to look with a flashlight and it is not to be found. Can someone shed some light on this for me?[dunno]
Thanks
1 - 10 of 10 Posts
· Registered
Discussion Starter · #4 ·
What I meant to say was the front of the tank on the passenger side. The photos in the link you posted are the same ones I have seen and mine is not in that location. Any other thoughts? When I pull the rubber grommet that the wires go through, all that is below it is tank.
· Premium Member
1 - 10 of 10 Posts
