Has anyone disassembled the fuel pump to look at the brushes on its motor? Can it be reassembled once taken apart? I've got 160k miles on the new style replacement pump. I cut an access hole under the rear seat years ago when replacing the sock filter on the assembly, so it is easily accessible.
The reason I ask is, brushes are usually readily available for a variety of applications and I've read where 180k may be the life of these pumps. If I can look at the pumps brushes it might give me a heads up. Thanks.
