1 - 6 of 6 Posts
okay so i have a but of a problem im pretty sure my fuel pump has went out but im trying to see if there is something small that im missing. and one thing i cant find evryone says that there should be a 15a fuse for the fuel pump but i do not see it on the inside of my diagram it only show a block fuse. can anyone help with this? and does anyone have any ideas?
One quick check--the fuel pump cutoff switch in the passenger footwell. If it's been tripped, you need to reset it.
Fuse #12 is for the fuel pump. Sounds like you've already found Relay R7.
The fuel pump cut-off switch pops up if it's tripped. Push it back down. Turn the key to ON then back off, then it should restart if that's the problem.
Fuse 12 is in the main fusebox by your left foot.
Turn key on and carefully listen for the pump to spin up for a second, if it does the cutoff switch is not tripped. You MUST hear that spin up or pump is not working.
1 - 6 of 6 Posts
