1 - 5 of 5 Posts
· Registered
How uch fuel pressure are you suppose to have in your car? My gauge reads about 34 PSI and when i get it some gas about 40 or so. IS that right? ANd when i give it almost full throttle like 60 psi
Thanks!
· Aurelius Pardus
really? that seems kinda low...i don't know though, I have an SPI and I get around 50 at idle and around 40 giving it gas...
· Force-Powered Focus
uve got a 2.0 right? the injectors are rated at 19lb/hr.
the ecu aims for 37 psi at idle, but can be pushed higher, like 55.
the stock pump can handle up to about 400rwhp.
  • Like
Reactions: BOOSTA
· Registered
Thanks!
Your fuel rail pressure should be at 40 psi at all times(acceleration, idle ect)and have a deviation of around +/- 1 psi, under acceleration and deceleration, the pressure at the fuel pump will vary a little with the fuel rail pressure, but the fuel rail pressure is the only important one.
1 - 5 of 5 Posts
