1 - 8 of 8 Posts
My wife's car which is a 2003 ztw wagon with a 2.0 zetec is having an issue of a fuel leak where the feed line bolts to fuel rail. Should I get a new fuel rail or just replace the bolts with longer ones and put lock nuts on it?
Moved to General Tech Chat, better location for most repair questions.
Alright y'all this is where its leaking.
One side stripped before when I was swapping out the alternator and that was replaced with a longer bolt and lock nut. The other side a seemed fine at the time but now it clearly doesn't hold so I'm going to do a longer bolt and locknut to that just to get it home
Discussion Starter #8
Yeah the oring was still there. The screw that I replaced was tight the other one backed out from lack of threads
1 - 8 of 8 Posts
