1 - 5 of 5 Posts
I am having a little trouble figuring out what is going on with my car. When I get on it in high boost, randomly the car just shuts down like a rev limiter or traction control is activated. Traction control is off, usually happens at about 5-6k rpm. Would this be a fuel cut, Misfire or bigger problem?
Current Modifications are:
  • [*]The BEAST intercooler(Problem was before bigger intercooler)
    [*]NGK one step colder plugs
    [*]MBRP 3" intake tube
    [*]AEM(K&N) Filter
    [*]MBRP 3" Catless Downpipe
    [*]MBRP 3" Catback Exhaust
    [*]Cobb AP V3(Custom tune by Troy Ramsey @ Panda Motorworks)93 Octane (Running Currently) & e30 tune ran on occasion.
    [*]Torque Solutions Throttle Body Spacer
    [*]Stock Turbo
Spark plugs are gapped to specs, gotten firmware update on the ECU because car is a 2015 and had a minor recall for rough idle. The custom tune has been ran by many in my area and have experienced no problems.
Thanks for your time and consideration for whoever responds.
    [*]AEM(K&N) Filter
    [*]Stock Turbo
Did you find the problem by chance?
PLEASE LET ME KNOW IF YOU FOUND A SOLUTION! My car started doing this tonight right after i installed the Stage 1 91 OCT OTS map for my COBB AP
1 - 5 of 5 Posts
