41 - 60 of 79 Posts
Discussion Starter · #42 ·
The smooth side is on the idler and water pump. So, I'm guessing it's a bad water pump or a stuck thermostat..can't decide which one to replace since I'm still not able to pick up a code
2004 ZX3 SVT EE 160k miles. 2004 ZX3 SVT 189k miles
The thermostat will be the easiest to change and usually the first one to go bad of the two. What I would do first.
Thermostat is cheaper, easier, and more likely to be a failure point. I'd start there first before doing the water pump.
Only times I have ever had a code for the thermostat it was the p0128, coolant not reaching temperature, thermostat stuck open.
10-4, 'ppreciate yall help. I'll let yall know how that goes
I normally go through the passenger side headlight opening to replace the thermostat on duratecs. Never tried it on the 08 and up.
Discussion Starter · #50 ·
Yes sir. That's how I did the power steering pump as well. So, I just replace the thermostat and it is still overheating
The gauge is going up or it is spewing coolant? Are the fans running?
Discussion Starter · #52 ·
Are y'all referring the water pump for the clutch fan or the coolant pump pulley?
the fan on your radiator. that can overheat the system if not running although takes a little longer to overheat.
Is the radiator fan kicking on as the car heats up?
Discussion Starter · #58 ·
Well, I just replace the Coolent Pump Pulley, but it did not solve this overheating issues. The radiator fan clutch is functioning properly as far as I'm concerned. Not sure what else it could be
There is no radiator fan clutch and why would you think a pulley could make it overheat?
Discussion Starter · #60 ·
I've heard that the propeller inside of it could had came loose for some reason. It was either the thermostat, coolent pump pulley, or the radiator. The hoses and everything else looks fine. No sign of leaks
41 - 60 of 79 Posts
