I've seen a few people asking about this so I thought I would chime in.
I have done MANY suspension swaps in my time (I am an old fart) and the Focus has given me more trouble than anything else... mainly... Frozen LCA bolts
IN the LCA there is a bushing with a steel sleeve in it in which the LCA bolt goes through and it threads into a lock nut thats tack welded to the LCA. Over time 2 things happen.. 1) they get dirt and rust in them 2) they warp.
There are a couple of things to avoid when removing them... HEAT is the #1 thing to avoid... it doesnt help at all. The bolts sieze up to the sleeve in the bushing not the lock nut.
You need either a very powerful impact gun ( I use an IngersolRand 660ft/lb one) or a long breaker bar.... sometimes even my IR wont break them loose.
Usually once the bolt breaks loose it will turn out until it clears the nut then it gets stuck again.... thats where warping of the sleeve/bolt comes into play.
There are only 3 options at this point...
1) cut the bolt off and pry out the bushing (of course you'll need to replace the bushing and the bolt is you cant get the bolt out after you remove the bushing)
2) use a punch and a hammer and drive out the bolt
3) use an air hammer with a flat tip (basically a punch) and drive it out that way.
Unfortunatly all 3 ways suck.
Sometimes the sleeve will come out of the bushing along with the bolt (it usually breaks loose from the bushing when you're trying to break the bolt loose) You can fix this with out replaceing the entire bushing.
Once the sleeve is out find a drill bit to fit inside the sleeve.... and redrill it back out to where it should be... incase you ever need to take it back off.
After you do that get some black siliconeand coat the outside of the sleeve and reinsert it into the bushing.. once it sets up a few minutes it will work fine and you'll never be able to tell it was even out.
Another thing to look out for is the nut will alot of times break loose from the LCA.... I usually just weld them back on. You can replace it if need be....
Depending on the shape of your nut and bolt you can always replace both of them if you have the time and tools at hand... the nuts dont HAVE to be welded on... but its just nice to have them like that.
Feel free to ask any other questions you may have.
