1 - 10 of 10 Posts
So about a month ago I heard this clunking noise in the front passenger side. I kinda knew what the reason was. So I ran out to Northside Ford for some discounted parts. ($16.25 each+tax with employee discount)
Wonder what this is....(possible JDM? lol)
Oh no just a OEM Ford endlink
Weapons of choice 15mm and #5 L wrench.
Jack up the car and remove the wheel make sure you use jackstands.
Your going to need your jack to put the suspension under some load.
Gotta disconnect this line and remove the bolt
Remove the rear bolt as well
Remove old hardware.
Drivers side
Passenger side
This shows the difference in the new style versus the old style
New part in place
Don't forget the bracket or else your gonna have to remove the bolt again.
All buttoned up
Cleaned up
Old and busted
And my custom made socket wrench(3/4) for the top nut on the strut.
Works wonders as the bolt was very slightly loose
Discussion Starter · #5 ·
Not a problem I figured since i've seen a lot of these questions come up I would do a write up with pics. Since I replaced them there is no more clunking/popping noise.
Is this a part that is a "for sure" source of noise from the front end? I get big noise when I hit some bumps with the SVT. I just figured it is hitting the bump stops. Is there a way to test the end links? For 20 bucks it might be worth replacing them.
Dan
Discussion Starter · #8 ·
Well if it's like a clunking/popping noise then that may be the culprit. When I replaced mine the sound went away. From the pix you can see why it was doing that.
Grab the link and try to move it laterally and vertically. If there's excessive movement or looseness, it's done. It should be snug, and the sway bar should move with the link.
FoFo Lover.
That looked like it was a really quick fix....I could be wrong. Any chance you scoring me those parts for that cheap? ;)
Great Write Up!
1 - 10 of 10 Posts
