hey all, my car makes a clunk under acceleration and deceleration on the front drivers side. i can feel it in my left foot a little bit on the floor.
car also randomly makes a rattle which sounds like the same front driver but i cant feel it and it sounds like its coming from the top. could be the filter i put on the EGR hose (valve cover to airbox) or my recently installed camber plates.
it also pulls MAINLY to the Left when i accel and MAINLY to the Right under decel. however there is no rhyme or reason to it... sometimes it pulls annoyingly, other times, nothing at all.
i had the car aligned 2x, take a look @ pics and the mechanics also tightened some loose bolts. helped out with some of the noises the car makes. a subframe bolt was supposedly a full turn loose, a front driver control arm that was a quarter turn loose.
this is my suspension mods list, dont know if necessary or not:
Vogtland Springs
KYB Struts
Eibach 22mm Front Sway - not greased.
Eibach 25mm Rear Sway - greased
Master Select Pro Sway Bar Endlinks.
Focus Sport Strut Bar
FSWERKS Front LCA Polyurethane Bushings - greased
FSWERKS Dogbone Polyurethane Inserts - greased
Nitto Neo Gen Tires
Ingalls 1* Camber Plates
CFM Front Steel Braided Brake Lines
Vogtland Springs
KYB Struts
Nitto Neo Gen Tires
