It seems carbon build up on intake side of the engine has been a problem in some gas direct injection engines of past designs. I'm wondering what Ford has done to combat this issue.
For those that don't know, in the typical engine cycle the valves don't actually close at BDC of the intake stroke. They remain open slightly longer in order take in as much air as possible, which is achieved with only a small amount of blowback. After time this blowback creates a substantial carbon deposit on the intake side of the valve head. The usual engines with port injection pass fuel with added detergents over the underside of the valve heads as it enters the cylinders to clean the carbon build up away. Direct injection has no means to clean the valves that I'm aware of.
