61 - 80 of 697 Posts
I'm with Sailor. Our 2013 is up to 37k miles and no complaints. I'm 72 and not in any particular hurry around town so i drive it like I did with all the manuals, leave plenty of room in front of me, get out of the way of people who want to drive a foot behind me, and let the kids have all the excitement.
Mind you, I didn't use to drive this way, but I ALWAYS kept space in front of and behind me, usually light speeding was the way to keep people off my tail. one accident in a bit over a million miles, and yes, it was my fault.
Have had the Focus for about a fortnight and I noticed something today, and that is when I have it in sports mode it never shifts to 6th (I tried cruising at 125km/hr, close to 3.5k RPM I think, don't remember). I like the delayed shifts of the sports mode but now I have to remind myself to put the car into 6th when on the freeway.
Is this normal?
It's a 2011 powershift but had work done on the trans under warranty by the previous owner earlier this year
In sport mode it's normal ... highest gear is 5th.
Unless you manually shift gears using the +/- button ... then you can use the 6th gear
Cmiiw
Cmiiw
Ahh sweet, was just checking.
Most sports modes on non-sports cars aren't a whole lot different from normal and still emphasise fuel efficiency, that's why I was surprised.
I've also found that the powershift is reluctant to down shift when you suddenly step on it. Sometimes it will, sometimes it won't.
I tried select shift but the shifts are incredibly delayed so not really a fan of that.
If you want a different sport mode, get a tune either from sct or injected. The tune will change the shifting point at higher rpm, so it will be "sportier" while still having good fuel efficiency.
Thank you for the write up, this is what I personally found about the Ford DCT, similar to other DCTs, just don't expect them to be automatics.
I had a 2013 Hyundai Veloster with the DCT and it was terrible, nothing compared to the one in the Focus.
To the OP, I just wanted to join up and thank you for the info.
I recently went for a test drive in a 2015 Focus Ti. It was a showroom floor model, loaded to the brim with all the features.
Coming from a 2000 Focus SE, this thing really handles differently. But at least I was relatively well prepared for how the DCT handled. And you know what? Not a problem. Yes, there were some stutters at the low revs (starting up from a full stop at a red light), or inching along a parking lot (or the dealership's lot), but it was no jerkier than if I was driving clutch myself.
Mind you, I am comfortable driving stick, even though my personal car is an auto. So to me the jerkiness was really very reasonable given how it would have been had I been the one shifting, not the computer.
Anyways, I get why WhatTheFocus has many concerns about the DCT, but all the same it's not as bad as many make it out to be. As someone who is confident at driving a stick, I will say that the DCT's slight jerkiness is nothing to be concerned about.
All that said, we don't quite know what changes Ford has made, mechanically or with software, to the DCT system. The new 2015s could just be that much smoother than the 2014s.
The DCT in my 2014 has been extremely smooth. Even inching through parking lots, it is just as smooth as the wet clutch VW that I had.
My focus has 12,000 miles on it, and during that time, the transition from first to second produced shudder, but somewhere around the 11,000 miles mark, the transmission smoothed out, and I have not experience shutter since then. I believe that this is due to the transmission not being entirely broken in. I drive mostly on freeway, so the clutch was not getting much use. During December, I made the concerted effort to drive only on surface streets, and use the clutch as much as I could, I figured, if you must fail, fail now. I also performed the "clutch scrubbing" technique, this eliminated the shuttering. Shudder should not be confused for low speed jerkiness, any DCT will jerk at crawling parking lot speeds. Shutter will be slippage during gear transitions, primarily first to second.
My 2013 with 30K is close to flawless during cold temps. Starting around November here in NC it got much better. My expectation is that around April we'll get back to the more normal quirky operation. I've even noticed the quirkiness when temps have gotten in the upper 60's during the winter. Maybe I need to move further north.. NOT!!
That's one thing I've been watching down here, is how the car behaves when temps change. So far it's gotten up into the mid 80s a couple of days, and gotten as cold as low 40s in the morning. The transmission behaves pretty consistently regardless of temp in my neck of the woods.
Oh, and don't move north, I just came from the north.
thanks for this write up!
now that im leaving more space in the highway stop and go traffic it is way smoother.
I do notice though when I get off the highway it seems to stuttuer from 1st to 2nd and sometimes from 2nd to 3rd. time to take it to a dealer? or do other people have this happen?
2012 sel powershift
10 months and 20k later driving one, I think it can be summed up in 3 steps:
1. Pretend you are driving a stick and don't want it to "jerk" in first gear. Simply give it easy throttle at first and after coming off the brakes at low speeds.
2. When they say leave gaps in traffic, all that really means is don't instantly jump on the gas with zero room behind the car in front of you. Simply allow a full car length or two so you can give ease into the throttle like in step 1.
3. If you do have some mild shudder once in awhile, then do a "clutch scrub", a "Mario Tuneup" for your DCT... Simply floor it and leave it floored until it shifts at redline for as many gears as possible. I try to do this a few times a day while merging on to freeways. This helps "remind" the DCT's adaptive feature to remember it needs to clamp strongly for powerful shifts sometimes.
(Optional) Adding a $9 motor mount insert has completely transformed my car from feeling like a an old Civic with 200k miles to sporty and responsive, including the DCT. Yes, I might have a bad motor mount but it was that way when I got it at 18k miles. Former rental it might have been abused, but still, only 18k miles the motor mount shouldn't be bad. Now my engine doesn't rattle at startup, I get MUCH better take off traction and the DCT is acting far better.
Excellent write-up, this has confirmed my feelings from driving the car that I just need to treat it as a manual, even though it's an automatic. I've seen several comments around the forums so far that the DCTs are "terrible transmissions" but I think that stems from a lack of understanding of how these things actually work. I've noticed getting off of the highway or idling at a light that the transmission works like a manual - it will slip backward if I've got my foot off the brake and throttle. For me this isn't an issue and I've quickly figured out how to behave in the car. Again, your write-up actually explains my assumptions, thank you!
