1 - 3 of 3 Posts
How do you tell which shift soleinod is bad. My Tranny slips into out of gear into neutral with o/d engaged and runs fine with it disengaged. How do you tell which one is bad.
BodyKits=PantiesDrop
Check engine light should show you but replacing the valve body will take care of it. I believe its Shift solenoid B as I fixed this same issue on another member's car. Been a while but when we hooked the scanner up to it it listed the cause.
1 - 3 of 3 Posts
