1 - 20 of 23 Posts
· Supporting Vendor
From the factory, the Focus RS uses incandescent bulbs for the turn signals and tail light bulbs. They light up white in color, and cast light through your red or amber tail light lens, which results in a washed-out color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off function, increased brightness, and true, vibrant color. By replacing the bulbs in your Focus RS, you can achieve this modern look.
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
HP48: (265 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP48: This bulb is non-polar, CK compatible, with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment
All three bulbs use a quality inject-molded 3157 terminal, with a full-size base connector and proper pin alignment, designed for exact replacement of your factory 3157 bulb.
*Resistors will be needed to prevent hyper-flash on turn signal locations
Included in your order is TWO BULBS.
Click to Shop: Rear Turn Signal LEDs for 2016 Focus RS (pair)
Click to Shop: Tail Light LEDs for 2016 Focus RS (pair)
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, email[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
http://www.youtube.com/watch?v=6aK_DICg1kk
How to Install 2016 Ford Focus RS Brake, Reverse & Turn Signal LEDs
· Supporting Vendor
Discussion Starter · #5 ·
July 4th sale! 20% off all diode dynamics products!
/center]​
HURRY! Only a few hours left!
Save 20% on all LED upgrades with coupon code: JULY4 at checkout! Head over to our website before this sale is gone! Sale ends Friday, July 5th at 11:59 CST!
Jake H.
Diode Dynamics
Click Here To Shop Now
Cannot be combined with additional discounts or free-shipping code
· Supporting Vendor
Discussion Starter · #7 ·
Don't settle for generic LEDs! Diode Dynamics LED Turn Signal Bulbs are fully designed and tested in St. Louis using the best components available. Additionally, we back every LED upgrade we offer with a 3-year worry-free warranty!
Don't forget to shoot us a PM for free USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
· Supporting Vendor
Discussion Starter · #8 ·
Our Black Friday sale starts NOW! Today through Monday, 12/2/2019, save 20% on all LED upgrades including our LED Turn Signal Bulbs by entering coupon code "BLACKFRIDAY" at checkout!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #9 ·
Our July 4th sale starts NOW! Today through Monday, 7/6/20, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #10 ·
Our Labor Day sale starts NOW! Today through Tuesday, 9/8/2020, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "LABOR" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #12 ·
This is NOT a drill! Our Black Friday sale starts NOW! Today through Monday, 11/30/2020, you can use coupon code "BF15" at checkout to save 15% on all LED upgrades, including our Turn Signal Bulbs.
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 11/30/2020. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #13 ·
Don't miss out on our lowest prices of the season! Through Monday, 11/30/2020, get 15% off all our LED upgrades for your ride, including our Turn Signal Bulbs.
Use code BF15
Collin
Diode Dynamics
· Supporting Vendor
Discussion Starter · #15 ·
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #16 ·
Our July 4th sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
· Supporting Vendor
Discussion Starter · #17 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our LED Turn Signal Bulbs!!! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.​
· Supporting Vendor
Discussion Starter · #18 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Turn Signal LEDs, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
· Supporting Vendor
Discussion Starter · #20 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Turn Signal LEDs, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
1 - 20 of 23 Posts
