Ford Focus RS Reverse/Backup LEDs! Plug & Play Install! See Comparison Pics & Video!
7771 39
Ford Focus RS Reverse/Backup Light LED
(Focus ST uses the same bulbs, here's another angle for comparison)​
Diode Dynamics, carries a full line of LED replacements, including three different levels of brightness for your Focus RS reverse light or backup light bulb (921). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Ford Focus RS model year selection.
Bulb Design
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Bulb Fitment:
The 2016+ Focus RS uses a 921 bulb size. We use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulbs and enjoy.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs.
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Shop Now: Backup LEDs for 2016 Ford Focus RS (pair)
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
1 - 20 of 40 Posts
· Supporting Vendor
Discussion Starter · #13 ·
Pretty sure I've seen that RS with the FF script on the rockers in IL.
The Nitrous Blue RS we had in our studio is owned by FocusRSShop.com
If you live near the Illinois / STL border, there's a pretty good chance you have seen it. He recently put on a set of BBS wheels, and added a custom-fab Panda Motorworks FMIC.
Nick C.
· Registered
Nick C.
I've seen it a few times. I live in the area and I've seen it on both sides of the river. Thing is SICK [ohcrap]
· Supporting Vendor
Discussion Starter · #18 ·
July 4th sale! 20% off all diode dynamics products!
/center]​
HURRY! Only a few hours left!
Save 20% on all LED upgrades with coupon code: JULY4 at checkout! Head over to our website before this sale is gone! Sale ends Friday, July 5th at 11:59 CST!
Jake H.
Diode Dynamics
Click Here To Shop Now
Cannot be combined with additional discounts or free-shipping code
1 - 20 of 40 Posts
