1 - 3 of 3 Posts
I noticed a problem with the car that Start/Stop is not working and normally this indicate some issues like low voltage etc however I have no errors lights on the cluster.
I decided to scan the car and found out 8 errors.
u0010, U0140, U0073, U0140, U0121, U0151, U0159, U0131
After Reset the car voltages look normal:
Engine Running : 14.5v idle, 14.3v on Load.
Engine off : 12.6v
Ac voltage : 0V
Voltage drop is normal.
The car is working fine with Start/Stop disabled that is the only symptom, Any idea please on how I can try to remove these errors?
Thanks
Visit Autofthings to review headlight uv protection in case you concern.
Engine off : 12.6v
Ac voltage : 0V
Thanks
Have you try to reset PCM to clear the codes and check the battery voltage?
This issue was from a faulty ELM327.
Tested with New Elm327, reset PCM and everything is working fine.
Thanks
Steve
1 - 3 of 3 Posts
