Hello everyone,
My focus just started acting weird today at first I tough it was the Transmission, but after reading for 2 hours on the internet I am not sure what is the real problem that's why I want to ask here if I am not in the right forum please point me the right one and I will close this post.
The car starts fine Gears goes #1 in D 1 2 or R no bang it goes in gear fine. The Fluid does not smell burn it's still pinkish looking there is no leaks when I look at my normal parking spot.
The problems is that at 20Km/h the car does not want to shift it will rev high if I press more on the gas pedal but If I just let it "idle" to 20 it will shift eventually then sometimes will do the same at 50 2nd gear I guess.
After reading a lot of potentials problems I am quite confused some place talk about thing like PCM calibration or update or just bad wiring or full "tune up" could fix what I am facing or the worst possible case tranny failure...
So I am just seeking more advice from where to move from here what are my option to DIY or test to pinpoint the real problem.
Thanks
Thanks
