1 - 6 of 6 Posts
Okay so when I finally fixed my car I used my fogs at night... then my dad said I had one out so I stopped using them for awhile and when I checked them again both were out. So I went and bought two new bulbs along with some silverstars for the heads ;). the heads work fine but the fogs are still out. they're installed correctly and everything but when I pull the light switch out they don't turn on. Anyone have and ideas? Thanks
I looked but didn't pull it out. What should I be looking for? Sorry still only 17 without much knowledge on cars.
AKA KILLA XB
do you have your manual? if so look for whch fuse is the one for the fogs. i would just check all of them just to be safe.
I'm sure your dad knows how to check if fuses work? there is a little thing that u put on both sides of the fuse to make sure current goes through em....
Discussion Starter · #6 ·
Ya my dad knows all that stuff just doesn't have the time to share the knowledge. So alot of the things I try to find out on my own. Thanks all I'll check the fuses and see where that gets me.
1 - 6 of 6 Posts
