1 - 9 of 9 Posts
· Registered
Hello...new rookie here. Just bought a 02 ZX5 dark blue 5 speed. Love the car so far; its a replacement for a rusted out 93 Escort GT. Both of the headlamps on the Focus have moisture in them. How can I fix that? I was thinking maybe drilling a couuple holes in the bottoms of the housings to allow them to breathe. They are the stock Ford units.
· Registered
Welcome, They are most likely getting condensation inside because the sealant is shot on it. I think if you drill holes you will get more condensation and end up going through bulbs like no tomorrow. Remove the headlights and then seal it back up. Thats what i did to fix the condensation problem in the headlight
· Focus Fanatic
I would remove the headlights and remove the bulbs, then take a blow dryer and shoot it
in the hole where the bulbs were until the moisture is gone. Then I would get some
clear silicone and run a bead of it where the lense meets the housing. Sounds like the stock sealant just isn't doing its job as well as it should, so adding a new bead of silicone should fix it right up and you shouldn't have anymore moisture problems. If you need to know how to remove the headlights or any other info, feel free to ask. Welcome to Focus Fanatics. I think you'll like it here.
· Registered
Discussion Starter · #4 ·
So remove the clear lense from the black housing,clean it up and seal it back up with rtv or something? Isnt there some kind of anti-fog spray i could put on the inside of the lense before sealing them to help?
· Focus Fanatic
Is it condensation, or are the lenses themselves dull and foggy looking?
If its condensation, do what I recommended in my first post.
This is what I'd highly recommend using to seal them up:
If its not condensation, then you'll need to wetsand the outside of the lenses to make them clear again.
1 - 9 of 9 Posts
