yes it is there was a grommet i found that has no wires in it so i went through there.thanks abunch guys!
oh and is that the power for your sub i see running under the fuse box?if so where did you run it threw the firewall.?
if you could find a picure of that that would be greatcan't find a good picture, but a "better" way to do the foglight mod is to open the relay and stick a piece of plastic (zip tie) to keep it from closing.....supposed to last longer and look more professional than using the wire jump metheod.
FYI: I did my fog light mod with a piece of wire and spades 34k ago and it works and looks fine still.
a zip tie? what are you thinking?I can't find a good picture, but a "better" way to do the foglight mod is to open the relay and stick a piece of plastic (zip tie) to keep it from closing.....supposed to last longer and look more professional than using the wire jump metheod.
