1 - 5 of 5 Posts
Hello all of you, first post here. I have a 2015 Focus SE that has factory fog lamps installed. The car was in an accident and and I bought it rebuilt. The fog lamps don’t work so I went underneath the car and there are no wires anywhere that would plug in to them. It’s like they took them out when they repaired the front end. Is there a factory wiring harness that I could get to get them working? Any advice to get them fixed? Thanks in advance.
probably gonna have to search around behind the bumper and figure out where the factory wires got tucked into. probably want to make sure that are ACTUALLY came with factory fog lights, might have just put a cheap bumper on it and painted it instead of the actual one that belongs on it.
Thanks for the reply. I found two wires with different plugs on them. The picture of the one with two metal plugs is on passenger side and the bigger plug is on drivers side. This car does have factory fog lights installed for sure. Do either one of these look right? Thanks again
pretty sure the first photo is of the connector for the horn. The other side has a plug into a harness.
1 - 5 of 5 Posts
