1 - 17 of 17 Posts
hello
im a newbie
what do i need to fit a focusRs engine in to my 3door non turbo 2l focus from 99.. are the Rs shell wider ore
hope some helpfull people can answer my Q [:)] ore have pic of the modification
Best Regards
Jesper
I think he's asking what he needs to convert his non-RS into a RS look-alike. If so you'll need:
External:
Front fenders
Rear quarter panels
Front & rear bumpers
Wheels
Headlights, foglights and indicator lights for both bumpers
Possibly suspension if you want the wheels to sit the way they do on a real RS.
Internal:
Steering wheel
Shift knob
E-brake handle
Gauge cluster
Seats
Pedals
Possibly other trim items (?)
If you want to make it the same in terms of performance, you'll need:
Savlaged RS engine and transmission, otherwise a turbo kit and gear ratio change
RS suspension, including entire front/rear assemblies (if you want it to handle like a true RS)
RS brakes, spindles & axles
I think that's about it...ask around, there's a few other guys on here who have done/are doing RS conversions.
Discussion Starter · #4 ·
sorry iwe have not explane me correct :eek:/
.. im thinking of buying a dammage Rs and converte the hole front whit engin and gerabox, axels, suspension ect... but im wondering, is the focusRs shel difrent ore wil all the things fit.. like a straight forward job ?
Focused Focus
It should be a direct swap but you would need the donor car as you will need almost all the wiring and pretty much everything else off of the car to make it work as it should.
Gan-San!
I wonder if it going to be our good old friend... uh... what was his name? Had an RS, painted it black and silver... then crashed it and bought an SE-R... ???
Good luck with that. We'd love to see it!!!
Discussion Starter · #11 ·
External:
Front fenders
Rear quarter panels
Wheels
Internal:
Steering wheel
Shift knob
E-brake handle
Gauge cluster
Seats
Pedals
i would like to contact some poeple who have played whit the Rs motor .. can you ore someone els help me [:)]
DTF
whoa this is completely different from what he was thinking. we were all thinking you were referring to the focus RS not an escort Rs. i personnaly know nothing about the escort.
Discussion Starter · #13 ·
STOOOP .. hehe .. I we have an escort .. but its not that car i want to build to an Rs Focus ;) i also have a focus
wow I read through this it makes perfect sense
he has a focus, and wants to convert it to an RS
that's about it, if you can get a wrecked RS then you're set
as long ad engine and tranny are still good
hope the brembo brakes are ok, and that the wiring is good
nice escort by the way, good luck
Discussion Starter · #15 ·
Yep correct [;)]
Definately get the whole crashed vehicle- that will make the conversion much easier because there are surely little things that you'd never imagine that you'd need if you just went to a salvage yard and picked up a motor and transmission.
For example, if the fuel pump is a larger flow version, or the fuel lines are larger- you'd need the wrecked car. If you didn't have the wrecked car- you wouldn't know until you couldn't get it to run- or worse- run lean and BOOM.
Discussion Starter · #17 ·
im also going after a complet car [:)] maybe there is other here at this site, there have done the job[rolleyes]
1 - 17 of 17 Posts
