Hey all, new member, old reviewer.
Girlfriend's ford focus just today decided not to start. I was at work and she thought it was a battery issue, came home tried to jump it once and no dice. Plugged in scanner and I got these 4 codes:
P060A cmf Mod00
Internal control module monitoring processor
P0128 Pnd Mod00
Coolant thermostat
P060A Pnd Mod00
P2107 Pnd Mod00
Throttle actuator control module processor
The car itself, when I try to start it, just clicks loudly. It acts more like there is an electrical issue. I'm at a loss. The P060 codes I'd think are the result of the P2107, but from what I have researched throttle body issues associated with this code don't really explain the fail to start up. The voltage also currently rests at about 8V (started at about 11V after it failed to start the first time).
Before I just start blindly trying to drive the voltage up via a jump, any ideas? I don't want to force juice through it and find out there's a short and damage anything. I haven't really had any car problems I couldn't immediately fix without just googling the code and replacing what the associated part error is so again I'm at a loss.
Also, the coolant issue code I'm not worried about currently because it's 20 degrees here so that kind of makes sense.
Otherwise suggestions are welcome! I'd rather not start off just replacing the throttle body as this isn't cheap and it doesn't seem like it will solve the issue.
P060A cmf Mod00
P0128 Pnd Mod00
Coolant thermostat
P060A Pnd Mod00
P2107 Pnd Mod00
