Little time for chat. Awesome post Thomas.
Most Foci have NO schrader valve (or similar) for connecting an external fuel pressure gauge, so here is what I ended up doing-> see post #13 ->
http://www.focusfanatics.com/forum/showthread.php?t=476818&page=2
I also did an exhaust back-pressure test after buying an appropriate low pressure test gauge. Did not check pressure while only cranking engine though... here is a post on what I did-> see post #3 ->
http://www.focusfanatics.com/forum/showthread.php?t=476906
I did not know that our Foci use the downstream O2 for fuel trim calc. I will have to go back and learn/re-learn some more about this. No hit on you, but I have a policy to doubt or believe nothing until after I have read it from two different sources.
I hope you stick around FF; new FF members (including peeps like me) need and appreciate people with your car Tech experience. Cheers!
1. There is a Schrader valve for pressure relief / testing on the rail.
2. You can't get an appropriate reading while the engine is running to determine back pressure. The pressure will fluctuate due to heat and fuel delivery. I'm only quoting the FSM.
3. True the down stream 02 determines the effectiveness of the CAT. It does this by recording exhaust temperature by generating a reference voltage (the hotter, the higher). Now, the upstream 02 Sensor determines the fuel trip for optimum engine performance.
Now, consider this, the down stream 02 Sensor is bad and is sending a arbitrary reference voltage, so the signal to the PCM for reference voltage is a cold engine (just started), if this were only for the CAT and did not communicate parameters with the upstream sensor, the PCM would command the injectors to be on infinitively flooding the chamber to increase temperature to increase CAT temperature. You would have a MIL with numerous Codes for MAP, IAC, 02, IAT, and so on because all these would be outside permissible lo/hi programming.
So, the upstream controls the overall engine management for exhaust gas temperature and the down stream makes it happen when needed for emissions (programmed allowances) of which this vehicle has a wide range (02 and before). Beginning in about 2011 they have become a problem for us (especially the DPF's). We see a lot of vehicles and replace a lot of sensors because of the regulations which will continue into 2020 under the mandate. There are constant updated flash programs for the PCM's. ** The real sad thing about this is, when the customers cars go out of warranty they will be left holding the bag, or paying the Piper as it were.
Now having access to the FSM is a great help. However, I won't cut and paste the information here as its proprietary.
As for the other comments with I do not.... The wonderful thing about science is weather you believe it or not..... its true.
The maintenance comments are spot on. The MIL illuminates for a reason. I would like to what the Europeans have included in their high-end vehicles for MIL's, they have two LED's, yellow / red. A yellow can be ignored for 50 or so miles, the Red indicates immediate service required.
I guarantee I could diagnose this in about a half hour with a lab scope and scan tool. However, the internet doesn't allow that and most people don't have what I have.
