1 - 20 of 25 Posts
· Registered
ok ppl i want to see pics of a focus with a wall idc what size or number of subs i am thinking of running a wall with two treo ssi 15' and a thousand watts to each since they are only rated 750rms a piece.... tuned to approx 35 hertz..im hoping to be ably to hit.....high 155 - 159 or higher..... low sixties wood b insane and yes i have the battery bank to power it....2k is nothing
· Registered
I'm not sure that you'll be able to hit 155 with just a thousand watts per... but wont know till you build it!
· Registered
If you want some 15"s that will handle power for competitions or even 18's for that matter.. i would suggest something found here: http://www.dcsoundlab.com/home.html
Here's proof that they get LOUD.. http://www.youtube.com/watch?v=M8j10sqfZB4 .... This is a vid of my friends 01 Neon right after installing 2 DC Audio Level 5 18's Walled pushing a total of about 3500 watts... Hitting about 154db with broken windshield :) Needless to say, we had to install a brace in the roof to stop the windshield from breaking... Again.. haha
· Registered
I can tell you right now it takes a HELL of a lot more power than that to pull high 150s or low 160s.....and tuning to 35hz is wayyyy too low of a tuning frequency to pull those kind of numbers.
· Registered
35hz is pretty low, but hitting 150db with that tuning isn't impossible... You will need more power though. If the wall is tuned at 35hz, you'll have a Low peak frequency, but you'll just have to tune and test to find out what frequency you run the loudest at. I'm Currently Running 1 18" sub in a 3.7cu ported box tuned at 36hz pushing around 1600w. Highest i've hit was a 146.5db, Averaging around 143.3db on a 1min run(I need a second battery hooked up to hold it at 146)
· Registered
not saying its not possible....but using the equipment he is talking about there is no way he could hit those kind of numbers...he would need a TON of power...
I 100% agree with you... [cheers]
While on the topic though, I thought about walling mine a few times, I just cant afford to lose the back seat just yet... and i dont want to slow the car down anymore than i have to.. I do like my music loud though, tough decision
· Registered
Discussion Starter · #9 ·
lol toally not...i can push a 43.2 with a thousand watts in a box tuned at 42 hertz wiht a treo ssx 18 in a box with 6 cubes...i have a kinetic 3200 and a kinetic 2400 so i have the power..all i need it another amp basically...hank can push a 147.3 with the treo ssi in a box with 3000 watts now... so now its deff not impossible...cooper is tuned at 35 and is doing a 50 to captain america ..in a box.
· Registered
A wall with 2000w would pretty much be a waste of time. If you're going to do a wall, at least make it worth the effort and put in some big subs like AQ HDC3s, Fi BTLs or Ascendant Audio Mayhems, and gobs of power. I would personally recommend Audioque amps and subs... great bang for the buck. A pair of HDC3s and 2 2200Ds or 3500Ds might get you well into the 50s.
· Premium Member
Treo's are one of the superior subs ive ever encounter.. there's a treo dealer in spi, il and theyr amazing.. good luck!
1 - 20 of 25 Posts
