Air coming in... would be strange. Maybe a lack of normal fuel pressure/flow. Have you replaced the fuel filter yet?
Video here. Lucky you, that's easier than my Focus.
https://www.youtube.com/watch?v=WNphjXBNuIE
Ömer Durmaz 2 months ago
Hello again, I did manage to start up the engine again, first you will need to fill up the hoses that leads the fuel 1-from the tank 2-to the engine, up with diesel. And then I filled the new filter with diesel I took from the old, then you will need to suck out the remaining air afterwards in the new filter, and you will need to do that process until you get diesel in your mouth literally(that's what I did) if you have to much air in the horses the fuel pump won't create enough pressure to lead the fuel.
Brook Campbell 3 months ago
Should have filled the filter with diesel first , if not thou will be in for a flat battery and a car that will not start.
