1 - 1 of 1 Posts
http://www.cjponyparts.com/cp-e-front-mount-intercooler-focus-st-2013-2014/p/FFSSTFMIK/
Kelly from Custom Performance Engineering to show us their Front Mount Intercooler fitting all 2013-2014 Focus STs.The cp-e intercooler was designed for specifically for the Focus ST so it is a perfect fit, direct replacement. This intercooler has one of the largest cores available on the market, 28” x 8.25" x 5.5”. This core uses the bar and plate design for maximum efficiency and has an internal fin to divides the air evenly though out the intercooler.
cp-e designed this to be a one time upgrade, so if you add more boost, this intercooler can handle it. The intercooler requires no permanent modifications to install and will work using factory charge pipes.
For more cp-e parts available at CJ Pony Parts check out:
http://www.cjponyparts.com/custom-performance-engineering/c/8_1001_282/
For more Focus ST parts available at CJ Pony Parts check out:
http://www.cjponyparts.com/ford-focus-st-parts/c/70000392/
1 - 1 of 1 Posts
